Donnie *
Flight distance : 3636782 ft
fans3d037974 Posted at 2017-12-10 14:01
Donnie I'm stuck here I just purchased a new ipad pro and and I was trying to get firmware issue resolved because on the RC it was showing the AC fw to be 1.11 but on my SD card I had 1.10, so I loaded fw 1.11 on and nothing happened the AC would not update, so the next thing I tried was to roll back the fw on the RC which I did to 1.6 but I still could not get the AC to load any of the fw? So I tried update the fw back to 1.7 on the RC but it keeps failing, I eveing tried your suggestion plugging thumb drive into back of remote but to no avail. At this point I dodnt know what else to do? Please help
Ok, first ( did you read my tips page from start to finish ?) my tips page to see if you get any ideas here . Make sure that if you are using any camera other than the X3 that you choose the camera form the product select box FIRST, then load the Bin file ONLY to the Sd card .
I don't know why you had 1.11 FW on the AC and then did you accidentally load the previous version of Fw to the AC ? And are now having issues getting back to version 1.11 .
I would just get back to version 1.7.8 on the RC and then concentrate on getting 1.11 back on the AC, keep in mind you may need to re link the AC and the RC to one another after the update , you do not always need to but sometimes you do .
Be sure to format the Sd card
****Are you getting a hidden file on the Sd card when trying to update to version 1.11 ? Also are you sure that it did not actually update and check on the "ABOUT " tab of the Go app to be sure if it is loaded .
*** the RC will jave NO IMPACT on wheter or not the FW on the AC will load or not , keep that in mind for futrure reference , also with the New I pad Pro you have the correct Go app for the Inspire 1 correct ? Remeber the Inspire 2 uses a diffent go app ( go app 4 I think it is called ) so be sure you have the ocrrect one loaded.
You may wish to use the old go app device to get 1.7 loaded to the RC. It really should work with the I pad pro if you have the correct go app installed, MAKE SURE YOU HAVE THE GO APP FOR THE INSPIRE 1 !!!
donnie
