SAFrankSU
![](https://forum44.djicdn.com/data/attachment/common/c2/common_12_usergroup_icon.png) lvl.3
Update: If I hit the power button once the first LED lights up. I've used a Phantom often so I would assume this indicates that it has little to zero battery life left. If I click once and then hold, the battery will act as if it is powering on then the lights will go out. If I hold the power button down for an extended period (5 seconds or so), all LEDS light up to which I assume all cells are OK. If I plug the battery in the 4 charging hub the first LED turns on (to which it means it's charging) then the 4th LED (closest to the power button) will immediately blink twice, pause, then repeat for a few times in a similar pattern. My manual says the temperature isn't satisfactory for charging purposes, but the battery has been in a room-temperate climate the past two days.
Any takers? |
