johnchao411
Flight distance : 45364 ft
Taiwan
The first thing should be checked is did you enabled the FPV mode? The auto balancing won't work if the mode has been enabled.
If there no change after the mode being disabled, then I'd suggest you to send it back to DJI for a replacement or something.
Btw, perhaps there's an alternative choice for that, start the DJI GO and activate the camera, select the "gimbal" in the settings, you could offset the gimbal horizontal angle here... |
