Donnie
Flight distance : 3636782 ft
Ok, so after the updates were completed, you went to fly but you are hearing a beep tone and you have a red light on the first far left led on the Transmitter is this correct.
You are still able to fly ? did you have a low battery or some other warning perhaps that was going off ? I am not sure if you have the updates done correctly because you should have had a green light on the Transmitter when connected to the aircraft and about to fly ? Did you notice that the first Led on the transmitter turned green when flying ?-
Did you happen to have the Transmittter sitting idle for a long period of time powered ON without the aircraft being on ? This would present the red light and beeping sound that you are describing. Did the first led light turn green ( On Transmitter ) when you turned on the aircraft and did the beeping stop then as well . If this is the case , keep in mind when the transmitter is ON sitting idle for more than 5 minutes ( approx) it will begin to beep and the red light will be on the first led, once the sticks are moved the timer starts over again, this is to prevent a Transmitter going dead by forgetting to turn it off and is normal.
_
If the above is true you dont have to bother with providing additional information.
Can you please turn everything to on like you are about to fly and take a screen shot of the "About " page. I would like to see what update versions have successfully loaded. The page looks like this. ( mine is from an old update , so the versions are a bit different, but this is the page i would like to see ) OR if you cant do a screeshot please list the Firmware versions and then jost post them to see Please.
