Geebax
TJF059 Posted at 2017-1-12 18:27
Geebax,I have been using the exposure wheel to eliminate the lines but then find the pic is a bit dark.Im very new to the whole drone arieal photography thing,but very eager to learn.I will continue to play with it to get it right.Thanks for your feedback
That's fine, but sometimes you need to over-expose some areas of the picture to get the best shot, so if you dial down the exposure wheel to get rid of the zebra lines, then you may very well be under-exposing as you suggest. Another tool you can use is the histogram tool, it is a bit tricky to use, and you need to study it on-line to understand it, but it gives good results. |
