matthew.gray
I had a minor crash (low speed, tips of a few props clipped off, no other visible damage). I did not fly it again right after the crash.
I bought new props and some prop guards which I installed. Now, when I start the motors with the combination stick command, the rear starboard prop spins very slowly. I tried taking off once and it immediately tipped over.
I tried swapping the prop with the forward port prop in case it was somehow the prop, but the rear starboard prop was still the slow one.
I tried unscrewing the prop guards and reattaching it, with no change.
The motor is secure in it's position and when I spin the props by hand all of the props "feel" the same.
VIDEO of the prop speed difference: https://goo.gl/photos/wfgtARfGHo4UU8eDA
Any suggestions? Are there further diagnostics I can run? Is it likely the motor got damaged in the crash? Is it likely I've somehow messed up the mounting when attaching the prop guards?
