FatedFilmsNC
13,335 feet (2.52 miles) before I started getting weak transmission signal, but that was my 3rd day of having the P4 and the only test i've done. I might just be repeating here but it is RECOMMENDED BY DJI to PUSH THROUGH when your range starts to get weak, and it will reconnect up again in 5-10 seconds (with perfect connection). I have personally not tested this yet, as I'm not typically filming things over 2 miles away, but it has been confirmed by DJI. I hadn't seen it mentioned in here yet so I thought I would. Everybody try that next time you go do a range test (Just make sure your RC Connection Lost is set to Smart RTH, just in case). I'll be testing later today and will report back, if it's true, I should be able to hit the 3.1 mile range it promised (all stock). Flying in Raleigh, NC from a mountainous landfill (above all trees/power lines/everything in sight, but still in the city).
**On another note, everybody make sure their antennas are positioned properly to get maximum range** This seems to be a huge problem, the lack of knowledge in how the P4 antennas are supposed to be set. There are tutorial videos by DJI about this issue. Thank you david.p.mann for bringing this up.
