Sounds like I'm another victim of the firmware brick job with accompanying "no signal" and no video output.... Well, I attempted to update my P3P on sunday. The update went fine for about 20 minutes and then the steady beep and steady red light... ugh! So I tried all day to reformat, reinstall, tried different SD cards but no luck. I tried everything plausable. I pulled the hidden log and saw the dreaded [08 00] and [15 00] devices not detected. From what I've read I'm up a creek with no paddle and it seems like the only option is to contact DJI. I purchased it last july and used it until about August. I put it away for the winter and now this! I'm just afraid that if the problem is inside the camera/gimble (the video out logic board), I'll be stuck with an expensive repair (the gimble is listed as a 6 month warranty) for a copter that was in pristine condition. No crashes ever. Always kept in a case. And yes, I did follow the instructions for upgrading to a T. So if this is known issue with some firmware updates, will DJI fix/repair since really all I did was update the aircraft like I'm supposed to?
Also, I'm getting no video feed and the no link error.
