endotherm
Flight distance : 503241 ft
Seriously, get a map and draw a 9km circle around the airport. That is a no-fly zone. You should be responsible for your own actions and not deflect your responsibilities. It's up to you to follow the rules, not finding excuses like saying the rules are vague, or that you'll alter your behaviour when the SWAT team kicks your door in and gives you a more "official" warning. It really does upset others that are trying to follow the rules and trying to persuade you that you may be doing the wrong thing, in the hope of you changing your behaviour. Just admit to your mistake and promise to move out to another park a couple of km further away. Problem solved.
Now, to your original problem. I don't know why the home point jumped. But it was about 500-600m away. There was also another warning that it was out of range (Maximum flight distance reached, adjust it in MC settings if needed). That looks like it is in training mode, where it keeps the aircraft close to you while learning, limiting the height and distance it can go. By jumping 500m away, you are now considered outside of that zone. I'm not sure if the software is happy for you to be there and at best will initiate some sort of return home, even though we didn't see that notification pop up. Whether it is trying to go all the way home, or just try to get back inside the "training" circle I don't know. My first thought once it wasn't responding to inputs and was wandering in that direction would have been to see if it had gone into that mode, and if so turn it off. Maybe that would have returned control? You are lucky you got it returned and in one piece, but I think it is worth having DJI examine your flight log and see if they can determine what went wrong. If it was hardware related, you definitely should get it fixed before flying again as it is unsafe. If it is software related, they need to know as it potentially affects everyone else flying out there.
