ggoodlett
Flight distance : 27978153 ft
Careful how you answer this seemingly simple question. Southern California is covered by the second advisory now. They seem to be scheduled for night and cover a huge area.
https://www.faasafety.gov/files/ ... Flight_Advisory.pdf
FLIGHT ADVISORY
GPS INTERFERENCE TESTING
NTC 16-03
14-18 April, 2016
Barstow, CA
GPS testing is scheduled as follows and may result in unreliable or unavailable GPS signal.
A. Location: Centered at 352435N 1163500W or the HEC VOR 338 degree radial at 37NM.
B. Dates and times:
14 – 18 APR 16 0430Z – 1330Z
C. Duration: Each event may last the entire requested period.
D. NOTAM INFO: NAV (NTC GPS 16-03) GPS (INCLUDING WAAS, GBAS, AND ADS-B) MAY NOT BE AVAILABLE WITHIN A 359NM RADIUS CENTERED AT 352435N1163500W (HEC 338037) FL400-UNL DECREASING IN AREA WITH A DECREASE IN ALTITUDE DEFINED AS:
331NM RADIUS AT FL250
217NM RADIUS AT 10000FT
196NM RADIUS AT 4000FT AGL
146NM RADIUS AT 50FT AGL
E. Pilots are encouraged to report anomalies only when ATC assistance is required.
The NOTAMs discussed in this advisory may change with little or no notice. Pilots are advised to check NOTAMs frequently for possible changes prior to operations in the area. NOTAMs will be published at least 24 hours in advance of any GPS tests.
Released
11 April, 2016 |
