quickpoint
always over, never under. if your RC craps out while under and rth kicks in. could be a bad day.
i have never gotten interference from high tension wires either, they do carry 50-500k volts, which mostly has noise between .01-1,000 mhz. phantoms operate at 2.4/5.8. power lines at your house and on streets, are very different. 10k+ top wires but the main interference from them comes from failing shielding in the transformers. Em interference between primary and secondary coils can mess wit you signal if shielding/grounding is bad or weak. |
