DJI-Ken
Flight distance : 1515312 ft
This is for the P3, but basically the same. The link button on your P4 is the LED next to the SD card slot. Power up the aircraft, RC, and app. Make sure if the aircraft is on 0288 then the RC has to be on 1.5.8. If the aircraft is on 1.1.301 then the RC has to be on 1.6.
With the RC and aircraft on Press the link button on the aircraft then on the RC press C1,C2,video, and you will hear a beep. Then press the camera settings dial and you will hear beeping and a few seconds later the beeping will stop and the RC LED will be green and you are linked.
It doesn't matter which order you link first, you can also put the RC into bind mode then aircraft.
