colobus
Flight distance : 45417 ft
colobus Posted at 2017-10-21 14:32
Thanks Paladin, Note that this AC & RC has never had a prior connectivity problem UNTIL yesterday when the RC firmware was updated using the connection via the USB cable between the mini iMac & the RC. Remember, I had no prior problems with anything on the PH3 Advanced!! I have cleaned my SD card (as previously stated) , so I do NOT have any data in the MISC file on my SD card. Is there anyplace else where it might reside? The comment ."adjusting the antenna during flight" is funny, considering I can't get a link between my AC & the RC, which means the AC can't fly, unless I manually toss it upwards into the air. I appreciate your follow up. From its history, I doubt there is a hardware problem, as it has a clean history UNTIl the firmware update. I am NOT getting past the start screen, so I cannot access any system info.
My apologies Paladin, The post was my error & I can't delete it. However, its subject is current, but on another thread, I was mixed up between the two. |
