Ipad Mini 2 stopped connecting after 2.7.2
12
4907 41 2016-4-24
Ezreal
China
Hi, it seems that something wrong with your iPad Mini 2 causes the problem. Before doing something, you can check if there are some failures with your device hardware. If not, you can consider using a repair tool to work for you. Sometimes, some serious system failures may bring out such an issue. If you do not restore iPhone because you worry about losing data, then consider a program called Joyoshare UltFix for windows to settle the problem. The software is designed to fix various iOS issues without the risk of data loss. If you do not mind using a third-party tool, you might as well have a try with it. Good luck!
2019-10-17
RedHotPoker
Flight distance : 165105 ft
Spamming the forum and a three year old thread?
Go away.
RedHotPoker
2019-10-17
12
