Geebax
That is not true, if you post a file then download that file, there is no compression. You only get it if you view the material using the Dropbox player, which is apallingly bad.
Having said that, I downloaded the 4K clip and I cannot see anything wrong with it. The scene itself is just about the worst scene you could choose for any system that uses MPEG compression, as it is almost entirely small foliage which does not compress well. Other than the fact that it was under-exposed, it looks fairly typical to me.
You might advise what computer you are watching it on (specs etc) and which player you are using.
