I also keep getting another warning. Gimbal roll reached end point. I do have the problem with tilted horizon. I Don't know if that has anything to do with it.
Hello Jeff, when your drone flies in S mode , it is normal because the drone will reach a large angle in high speed flying.If you meet this issue in P mode, feel free to post a screenshot here.
means the drones angle of attack(tilt) is too great. this can happen with you are in sport mode doing heavy maneuvering. you can loose gps links, and the gimbal tilt far enough to handle the angle of tilt
I am still getting warning gps data exception my firmware is up to date I'm using lpad pro 9.7, being asking for answer since Friday, please can you let us know exactly what warning means..
