nigelw
Flight distance : 518084 ft
As far as I know, there are no user-serviceable parts on the P3 other than the gimbal suspension rubbers that can split & the props. The best you can hope to achieve as far as I know is to just check the condition of the aircraft & its moving parts. Make sure the motors don't grind or feel rough, maybe check the temperature after each flight which might increase if there's a problem, check the props for damage/chips/cracks etc., check the shell for cracks, check all the screws are tight/present.
Also, check the RC for damage or loose screws or controls. |
