imagesbyjas
Flight distance : 286198 ft
mdazel,
So we've heard DJI say, rather categorically, that nothing (at least to their knowledge as one of your posts inferred) was changed relative to power or distance. You referenced my flight data which I'm more than glad to post for anyone to look at, but I'm also trying to understand what it will show? I may be showing my own ignorance here, but is there specific information in the flight logs relative to transmissions and receptions? When I look at the playback in the flight log, I can see that RC Control Stick movements are tracked. Is there another (or different) file you're referring to?
Also, and a suggestion.... First, I really think you should be able to back things off to 1.7 (on the aircraft) and 1.5.8 on the RC. I believe you mentioned you tried and couldn't re-link (which is a problem in itself and may be pointing to an issue in the RC?).
If you can get that corrected, you could then re-produce and video the meter differences between 1.7 and 1.8 that you say you are seeing. I'm not going to doubt your saying what you believe you're seeing and I think that DJI seeing it on your RC and Aircraft could be valuable especially if it is reproducible at will.
We have people who have had a chance to fly say they've seen no difference with 1.8 for distance.. Penetration could be different, but we have no thoughts or evidence there I recall in this thread. Again I don't know what flight logs show, but there are some folks still on 1.7 and others on 1.8. I still have my 1.7 flight logs as well.. |
