robert.p.johnso
Sweden
5 day old drone, number of problems that ive learned to fix and understand but this on is totally confusing me.
just want to say that im pretty confidiant with sd cards owning to much equipment that relise on it, including gopro, zoom mics and canon cameras. so i thought i knew enough but this one has had me going crazy.
The drone is up to date.
when I record with the drone i sometimes come back and they are files missing.
i have done everything, left the sd in the drone for up to 2 mins after i have stopped recording. one time i had film in two clips in 1 flight so when i went to look at them it was only 1 file and it was missing a short file of 5 mins that was not so important but i had seen here that if you place the card back in the drone it might recover it,so i put it back in and it did deleted everything from the sd card before i had chance to transfer it.
is there a step by step on that process? if you turn the drone off and on again does that mess up the recover file process?
they are a few things i want to know:
what is the format of the sd card that goes into the drone? ex-fat, ms-fat....
i wish to reset the 8gb card that came with, also i have a 16gb (same make and speed as the freebie) witch has been in a gopro it whole life doesnt seem to like the like just yet so what to factory reset it for the p3
what can you do by putting the usb cable into the gimbal and does that usb slot work?
my main problem is that sd card, just want a bit more secuirty when im out recording something that i dont have to use the 240p that records to the phone haha
thankyou in advanced,
