scschulte
Flight distance : 159370 ft
When I charge the P3S batteries from a low level (say 10%) to 100% I first get 1 LED blinking, then 2 then 3 and finally up to all 4 and when the charge is fully complete - the battery lights go off completely.
I unplug the charger, and if I touch the button on the battery - I get 4 full green LED lights. Fully charged.
So after leaving a day or more I then used the battery to start-up the P3S just to show some friends. I did this a few times, but didn't start the props turning - just showed how the P3S started with the camera, gimbal, lights etc.
But this morning I thought I'd better top-up the charge so plugged it in and nothing. Same with the second battery. Both batteries show 4 full LED lights when the battery button is pushed.
So I am concluding that although the batteries may not be at 100.00% they are probably 96-98% and so at that level, when plugged-in to the charger, this is considered essentially 100% so no further charging takes place.
IS THAT CORRECT?
Tonight when I plug-in the battery to the P3S I'll note the battery charge read-out. I don't think I've ever read 100% -- mostly it reads max 98%--- but I assume that the charger won't do any more charging after that 95% level is reached? (Also guessing that the intelligence here is not the charger, rather this is in the battery itself-- is that correct?)
Thanks for any comments.
Best regards,
Steve Schulte
Wednesday 11 May 2016
