Dyeing P4 Propellers
123Next >
7115 101 2016-5-17
Maxi3D
Flight distance : 307621 ft
Has anyone tried dyeing P4's propellers? I wonder if the props will dye with its glossy finish.
2016-5-17
Damager
Flight distance : 9052 ft
Yes you can - just use Rit Synthetic Dye.
2016-5-17
5horns
Flight distance : 7779 ft
I would think that would add a little weight, but it looks cool.  I was wondering if anyone had tried to make quieter blades. It almost sounds as if the electric motors make the most noise. I was videotaping a middle school track meet, with permission of course, and every head was up till I landed it. Very distracting even though I stayed above 200 feet.
2016-5-18
Exib
Flight distance : 153760 ft
Damager Posted at 2016-5-18 02:02
Love those props,
2016-5-18
visitkans
Flight distance : 80413 ft
They dont add weight at all, weighed them before and after anf each one was exactly 12 grams.
Used rit liquid dye
2016-5-18
Exib
visitkans Posted at 2016-5-18 10:44
Would you guys that have done this please provide a guide as to the best way to get a good finish
The guides I have seen are talking about dying fabric
2016-5-18
visitkans
Exib Posted at 2016-5-18 10:51
Here is what i did
The process is...
heat water to around 80 degree C, mix the dye in it, and in a tray or bottle, immerse the props and let it stand for 2 hours, if you want a deeper colour, keep it in for longer.
Some cook the props in hot water to reduce the time, but i was a bit scared that i might deform them, so kept it longer in hot water.
Black was the longest, took 20 hours, it turned blue to dark blue and then black.
Deep orange is 8 hours.
As you see its quite easy to do it, if you dont mind waiting longer, then warm water and overnight dipping and you should be good.
2016-5-18
Exib
Ok I understand the part about mixing the dye in a pan and heating it, so you then laid a tray or container put the props in there and cover with the liquid from the pan leave for 2 hours or longer
Does it matter about the liquid then cooling, like the colour black you left for 20 hours so the liquid must have been cold
Did you the Rit Dye powder or liquid
Is this the correct product
Rit DyeMore Liquid Synthetic Fiber Dye Nylon Polyester Clothing AcrylicRit DyeMore Liquid Dye
Rit DyeMore is a synthetic  dye that will color 100% polyester, acrylic, acetate, nylon and  polyester/cotton blends. The Stove Top method—dyeing the items in a pot  on the stove—is recommended especially when dyeing polyester and  acrylic, because a very high temperature is needed to dye these fabrics.  Nylon tends to dye very quickly and much darker than the other fibers  so the actual time needed in the dye bath is much less.
2016-5-18
visitkans
Exib Posted at 2016-5-18 11:12
Ok I understand the part about mixing the dye in a pan and heating it, so you then laid a tray or co ...
Cooling of the liquid is fine, it just takes a bit longer, black one was dark purple after 14 hours, so just left it in longer.
The liquid one is easy to work with compared to the powder,
Get a small disposable baking tray or any wide mouthed bottle to immerse the props in
Here is the one which i used, but dyemore also works.
2016-5-18
Exib
thanks for your help I have ordered Racing Red
2016-5-18
visitkans
Exib Posted at 2016-5-18 12:41
Thats a lovely colour...
2016-5-18
Flying Poptart
Flight distance : 734577 ft
Damager Posted at 2016-5-17 21:02
Your yellow looks awesome!
2016-5-18
Maxi3D
Thanks for all the information. I try the Synthetic first. The natural dye doesn't works as well on my P3S propellers.
2016-5-18
SajidShah
Flight distance : 627539 ft
Portugal
Awesome guys
2016-5-18
microcyb
Flight distance : 1095955 ft
visitkans Posted at 2016-5-18 05:58
Here is what i did
The process is...
Oh wow, that is some cool stuff.
Thanks for the ideas and steps!
2016-5-18
Exib
microcyb Posted at 2016-5-18 14:41
Will let you know how i get on when the racing red arrives
2016-5-18
scschulte
Flight distance : 159370 ft
Exib Posted at 2016-5-18 10:16
Please do! I'm a red fanatic-- Volvo S60 red…  love cherries… Nosecone of my Belgian Flag Rocket…
Is the amount of liquid dye to use per x amount of water specified on the Rit bottle?  (I would imagine it is, but as this is mainly used for fabrics…)  Are the DJI Phantom 3S props nylon?
Thanks!
Best regards,
Steve Schulte
Wednesday 18 May 2016
2016-5-18
connorschulte
Flight distance : 261033 ft
scschulte Posted at 2016-5-18 10:24
Please do!  I'm a red fanatic-- Volvo S60 red…  love cherries… Nosecone of my Belgian Flag Rocke ...
I personally won't be painting my props as I do like the sleek look of the Phantom.
The colors do make it stand out though.
2016-5-18
Maxi3D
scschulte Posted at 2016-5-18 11:24
Not sure if the P3S props are nylon. I just dumped a whole bottle of the dye into a pan and diluted it with small amount of very hot water just enough to submerge the props. I waited the water to cool a bit before I put my P3S props in. You will have to soak it at least 4 to 5 hours. They came out very nicely.
2016-5-18
microcyb
Exib Posted at 2016-5-18 11:16
Excited to see this and try it out.
Hmm, dye the controller next?
2016-5-18
connorschulte
microcyb Posted at 2016-5-18 11:17
Would that require you to disassemble the RC? Wouldn't that void the warranty?
2016-5-18
microcyb
connorschulte Posted at 2016-5-18 12:57
Oh I stripped down mine on day 1 and rebuilt it. Of course don't do it if you are not sure what you are doing and yes that does void the warrenty.
2016-5-18
connorschulte
microcyb Posted at 2016-5-18 12:01
Oh I stripped down mine on day 1 and rebuilt it. Of course don't do it if you are not sure ...
Wasn't planning on it. I like the sleek white look on the controller.
Don't want that warrenty gone.
2016-5-18
Damager
If you heat the water to between 180F and 211F (just below boiling), the entire process only takes 20 mins or so (thats what I did for the yellow props).  Just keep stirring.  Also, the black and silver rings stay that color and are very easy to see, even after dying.
2016-5-18
Damager
Good call on the Racing Red.  I have a bottle sitting here for my second set of props.
2016-5-18
microcyb
Damager Posted at 2016-5-18 13:08
post photos!  I ordered some of that dye now also.
2016-5-18
Exib
microcyb Posted at 2016-5-18 18:37
Yea will hopefully get it done this weekend
2016-5-18
Exib
sorry double post
2016-5-18
Maxi3D
Exib Posted at 2016-5-18 07:41
Do be careful when using the red dye or it will looks like a massacre just been committed in your house.
2016-5-18
Damager
Maxi3D Posted at 2016-5-18 13:14
Do be careful when using the red dye or it will looks like a massacre just been committed in you h ...
Yes, but it would have been a Racing Massacre.
2016-5-18
Damager
Racing Red!
2016-5-18
Damager
BTW - that only took about 5 mins at the right temp.  I actually wanted them a bit lighter.
2016-5-18
ProQuad
Flight distance : 20296870 ft
Wondering if dyeing them makes them unbalanced???
2016-5-18
Cale262
ProQuad Posted at 2016-5-18 21:07
They look so good I'm going to give it a shot, just ordered cherry red and black from Amazon, I'll check them afterwords to make sure they are still balanced and post it up here...
2016-5-18
Exib
They look darker then I thought they would
2016-5-18
visitkans
Exib Posted at 2016-5-19 06:57
You can control the colour by lowering the water temperature, will take a bit longer, but you can take them out to check for the right tint of your choice, if you want it darker leave them longer.....
2016-5-19
Exib
How much of the bottle of dye did you use?
2016-5-19
Maxi3D
Damager Posted at 2016-5-18 20:54
It's good to see the high temp didn't affected the propellers. I will give it a go.
2016-5-19
Damager
Exib Posted at 2016-5-19 00:57
Agreed.  I'd like a bit lighter.  I think you can achieve it - just don't spend more than a couple of mins in the dye.
2016-5-19
Damager
ProQuad Posted at 2016-5-18 22:07
There is a thread on this going on over at PhantomPilots - several people weighed and checked balance after dying and there was no change.
2016-5-19
123Next >
