jesolins
Flight distance : 2169 ft
Hi Gents,
Thanks for the responses.
The camera works fine on another P3P so that is not the issue.
I also replaced the OFDM with a known good working one, so that is not the issue. Both of the OFDMs which work fine on another P3P. However on this P3P that I am troubleshooting, neither of these good working OFDMs will go into bind mode for linking the controller. The OFDM LED blinks orange.
What does that mean and what should I check?
The cables all check good with a digimeter continuity check.
Can you please post a list with the software update log codes to help us troubleshoot.
This is the problem line on the failed firmware upgrades:
[00540386][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
What is module 19 and where should I check for a fix please?
Thanks and Cheers,
Jim
