Donnie
Flight distance : 3636782 ft
The firmware on the RC and the aircraft are not supposed to be the same. Do you mean you have the correct match ? AC 1.8 and RC 1.6 ?
The Aircraft and Camera should be at version 1.8 and the RC at 1.6. When it went in for repair did you sent just the Aircraft correct? you did not update the RC while the AC was in the shop did ya ?
Can you look on the about page on the Go app and tell us what versions are currently loaded ? This may not work , try and see what versions are there though ....
For shipping the Aircraft was placed in Travel mode, once you get it out of travel mode, get it updated,( see instructions attached as well )
Can you get the aircraft out of travel mode from the Go app ? Or you can also cycle the landing gear switch 4 times quickly as well .
Also as flightime said, update the aircraft to 1.8, if it is already updated it wont hurt anything . You did not update the RC while that was in repair did you ? If you did rollback the RC to 1.58, get the aircraft out of travel mode, then load 1.8 on to the Aircraft , then update the RC to version 1.6
**You will not be able to get the Aircraft out of travel mode until you are able connect with it. I will also give a link on how to manually lower the gear, it is simple. It will be on mext post of mine.
This definitly sounds like the RC and aircraft are not on compatible updates. If your aircraft is on 1.7 then the RC version 1.58 would be a match . I f the AC is on 1.8 then 1.6 for the RC would be a match.
It was critical for the latest update the Aircraft be updated first to 1.8 before the RC to 1.6
****Nothing is going to respond until you get the correct update on the RC and Aircraft .....
Start here let me know
donnie
