First post here, so hello everyone !
I have a very similar problem to paulmcmullin on my I1 Ver.1. I think that problems started after the upgrade to 1.8.1.00. I'm not 100% sure because I only did a few flights on the previous firmware.
Trying to find a pattern here, and after 5-6 batteries it seems the RC (and sometimes tv) signal gets worse and eventually disconnects after about 7-8 min of flying (RTH kicks in).
As it was suggested at this and other forums, I have tried to downgrade both the quad and the controller and unfortunatelly I can't see any difference. Seemed a bit better on the ground since I stopped getting the low rc signal warning in the app but same problems started happening again in flight.
I am following the recommended practices when it comes to antennas setup. I have to almost constantly override RTH which is not fun when you've got 3 minutes of battery left. Getting a bit desperate here .
I'm back on the newewst firmware, done the IMU calibration but again - no progress. Also I've been flying in LOS no further than 150 meteres from the transmitter. Any ideas will be greatly apprecatied. Sorry for the flood of information in a single post, hopefully it makes some sense.
