Is it normal for the S900 to be beeping when plugging in the battery and nothing else..?
I am doing a test to see if it's ok, however the ESC's are beeping
Thank you this is resolved... issue was because there was no signal going from the flight controller to the ESC's.. I'm using the Pixhawk and therefore have to "ARM" the pixhawk first and the beep'ing stops..
