Litchi For DJI how to maintain an altitude relative to ground level.
3267 10 2016-6-4
gustofusion
Litchi For DJI how to maintain an altitude relative to ground level. Follow along
in this easy tutorial and fly safely with Litchi for DJI quadcopters.
[backcolor=rgba(28, 28, 28, 0.901961)]https://youtu.be/4nEhjHukM3k
2016-6-4
mrbill
Flight distance : 717100 ft
Great work!
2016-6-4
malvern
Brilliant, will save me lots of time.
2016-6-4
EdM
Flight distance : 1491814 ft
Thanks, bet I can find a use for this info pretty soon.
2016-6-4
jag01usn
Great job.  Now if that could be incorporated into the Litchi App that would be fantastic.
2016-6-4
gustofusion
Just keep in mind, trees aren't taken into consideration, nor are guide lines or towers or power lines... {:4_142:}
2016-6-4
wam8
Pakistan
gustofusion Posted at 2016-6-5 07:34
Just keep in mind, trees aren't taken into consideration, nor are guide lines or towers or power lin ...
Very Helpful, Thanks
2016-6-4
BadgerDog
Excellent tutorial ... very helpful... appreciate it ..
I just bought Litchi, so this will be very useful...
Regards,
Doug
2016-6-10
MD_Icarus
Thanks!  You answered a question I placed on a prior thread about relative altitude!
In your experience, how accurate are the ground elevation data maps?
2016-6-10
gustofusion
MD_Icarus Posted at 2016-6-10 11:49
In your experi ...
I would say within 10-15 ft on average. Just consider wires and trees before a flight
2016-6-12
PhanFran
Flight distance : 4804163 ft
Belgium
gustofusion Posted at 2016-6-12 15:55
Ok, but if you ste your height above the ground to 45 m and you make sure thaere are no powerlines in the path it would worok, right ?
I tested your system for a trip to Itally where we have a house on a hillside. I set the flying height to 45 meters and then made a path to the center of town which is considerably higher on an other hill.
So the path starts at 45 meters, goes down to -21 m at the bottom of the valley between the two hils and thengoes up again to 85 at th etop of the town on top of a castle that probably will indeed be some 40 meters high. So, even in the valley where the waypoint says "-21" it will still be 45 m above ground level, right, so that I don't hit threes or (normal) houses in the valley  ?
Thanks for sharing by the way !
2016-6-12
