i have completed 10 flights no with my P4, totalling around 2 hrs flight time and spotted this stress crack after my last flight? It appears to be developing from the area next to one of the hex bolts which holds the bottom grey panel on. I haven't opened it up myself, it's has only been flown in sports mode for a very short amount of time and so far (touch wood) no crashes! Surely this shouldn't be happening so soon in its life cycle? A bit disappointing really.
It is obviously not right but the only way to get it repaired would be to send it back. Do you really want to wait weeks for it to be fixed? Personally I can't see it causing a problem. Just keep your eye on it for now.
I belive you guys in the UK have a nice and friendly climate for plasticky products. If you guys experience cracks up there with your birds, I wonder how they could cope with the high temps and humid tropical climate here. I've got an 11 yo British truck that has cracks all over the dashboard now.
I completely agree, I've already had to return one P4, I made my initial purchase in April and have only just completed 10 flights, so it's been a labourious process so far. I definitely don't want to be without the drone for another couple of weeks, the weather is fairly good here atm, and being the UK I'm sure it won't last long!
I'd be less worried if there were more spare parts floating around over here.
James I'm sorry to hear about the crack on your bird, and I understand how you feel on the lack of spare parts being available to you, as I'm experiencing the same parts availability too here on my side. I hope that it won't get worse, and maybe you could have a shell readily available to you very soon if you want a quick fix.
About trading weathers, as long as I can fly the bird then I'd gladly do that ha ha
Sorry for your issue, James. It is recommended to get in touch with our tech support and send the drone for fixing.It would be better to leave me your drone's serial number.Thank you.
Thanks for the response DJI Paladin, the units serial no is 07DDD3T 0A10124. So this is something that definitely requires fixing then? I've already had one replacement and didn't really want to be without my P4 again for several weeks.
