endotherm
Flight distance : 503241 ft
It was only 74 millivolts lower than its closest cell, and only qualified as a Major Deviation by 4 millivolts, otherwise it would have been ignored. It happened only once, during the crash cycle where the motors were going berserk trying to correct the fall.
According to Healthy Drones, this isn't a cause for concern, it isn't a failure as such, rather something to keep an eye on with respect to the life/health of the battery in future.
Major Deviations ™
Major deviation is when a cell differs more than 0.07v from the other cells.
Please note that normal batteries can have a few of these.
An abnormal battery will:
A) Have most of the major deviations in one cell
B) There will be multiple major deviations per minute, and more than 10 total
C) The deviations continue longer than 1 minute
If your battery shows all symptoms (example, another) then this is considered a more severe case of an inefficient battery and may impact the battery life.
If your battery has only 1-4 instances on the same cell, don't worry too much about it. If it has 5-10 instances - then continue to track and make sure it does not degrade: |
