Phantom 4 Firmware 1.1.411 has been released
123Next >
7580 109 2016-6-6
rliamharpurb
I brought a p4 yesterday updated the rc and bird after 2 flights the esc failed
I swapped it today for A new one and no problems with esc however
There was no update for my rc this time
The video feed for photos is blurry compared too record mode, and the feed keep dropping out on my iPad which I was using yesterday, tried my iPhone 6 and seemed a lot better what gives? Should there be an rc update? I thought there was,
I should add it was dropping video approx 120m distance about 40m height
Also have altitude drop when stopping about 2-5m
2016-6-8
vanjones37
Flight distance : 1652674 ft
ronstitt2015 Posted at 2016-6-7 16:55
I had the same problem. If I remember right it was the "over exposure warning" switch was set to o ...
Will give it a try thanks alot
2016-6-8
alyphixal
Maldives
New firmware v.1.1.411 is only for Aircraft?
2016-6-8
Exib
Flight distance : 153760 ft
DJI-Ken Posted at 2016-6-7 17:25
The firmware issued yesterday for the P4 is 1.01.411
Well Ken you guys got it right this time, firmware upgrade went perfect using iPad Air 2
Many thanks to DJI for taking the time with this firmware release
2016-6-8
SectorDrone
Flight distance : 919751 ft
Does it fixed the altitude drop? I am getting mixed results from the foum...
Anyone can confirm... Dji ken ? Dji paladin.?
2016-6-9
Tmygun
Flight distance : 2972497 ft
alyphixal Posted at 2016-6-9 00:33
Yes......it's only for the aircraft.
There is no corresponding RC update.
2016-6-9
Tmygun
SectorDrone Posted at 2016-6-9 06:05
Anyone can confirm...  ...
Can't speak for everyone but for  me, and I only had a slight drop during full stops, it took care of that problem completely.
2016-6-9
rliamharpurb
I get drops in all modes
About 3-5m in sport
2016-6-9
Aardvark
Flight distance : 384432 ft
Try downloading DJI Assistant 2 and do update from a PC.
2016-6-9
DJI-Ken
Flight distance : 1515312 ft
SectorDrone Posted at 2016-6-9 18:05
You have the P4, what are your results.
Yes, it fixed it.
2016-6-9
MD_Icarus
DJI-Ken, or anyone, please let me know the answers to my questions below:
If you use the pc and go from the old firmware version 301 to the latest version, will it also update the batteries?
The reason I ask is because I saw that the latest version does not update the batteries?  Do I have to upgrade to .410 first?
Assuming it will update the battery,
Since the battery firmware is not stored in the sd-card on the P4, then when I place a new battery and reboot, how is it going to locate the battery upgrade?
Do the additional batteries need to be updated using the app? I can see how the app will push it over, but how is/(are) the extra battery(ies) going to be updated if I use the pc/DJI assistant 2?
2016-6-9
DJI-Ken
alyphixal Posted at 2016-6-9 12:33
Correct, it';s fro the aircraft only.
2016-6-9
DJI-Ken
rliamharpurb Posted at 2016-6-9 05:34
I swapped it today  ...
Can you please upload your DAT file of that flight and also post a video. You should not be getting video drop outs at that close range. You are in an open area correct?
Also, you said iPad, which one. Just an iPad will not work. You need at least an iPad Air.
And a very slight altitude adjustment from full speed to stop is normal.
2016-6-9
DJI-Ken
Exib Posted at 2016-6-9 14:25
Many th ...
Thank you for the kind remarks to DJI.
I know sometimes it can be frustrating sometimes. As time goes on, updates on new aircraft being released should get easier and easier.
2016-6-9
DJI-Ken
Tmygun Posted at 2016-6-9 20:43
Can't speak for everyone but for  me, and I only had a slight drop during full stops, it took care ...
A very slight drop from full speed to abrupt stop is normal, BUT if you have none at all now then that is great.
Possibly you have your settings just perfect
2016-6-9
hungdang
Flight distance : 4831962 ft
MD_Icarus Posted at 2016-6-9 22:03
If you use the pc and go  ...
Use DJI Assistant 2 to update the firmware from 301 to the latest, the process will update your battery as well.
While still connected your phantom 4 to your pc, turn off your bird, put new battery in then turn the bird on, the DJI assistant 2 will ask you to update the battery, click confirm button to allow the battery to get new firmware. Do this for all your batteries.
2016-6-9
DJI-Ken
hungdang Posted at 2016-6-9 22:44
Use DJI Assistant 2 to update the firmware from 301 to the latest, the process will update your ba ...
Thanks for posting
2016-6-9
rliamharpurb
DJI-Ken Posted at 2016-6-9 15:09
Can you please upload your DAT file of that flight and also post a video. You should not be gettin ...
Ken it's an iPad mini 2
I've tried again today and had 2 drops during a long flight so all seems good
Photo preview is still really blurry however
And I have some horizon tilt issues?
Thanks for replying
Liam
2016-6-9
rliamharpurb
Dji-Ken you mentioned to Tmygun he must have his settings just right to stop the altitude drop, where can I find this information and what settings to change?
I'm new to drones and just want to iron out the few bugs I have
Thanks again
Liam
2016-6-9
DJI-Ken
rliamharpurb Posted at 2016-6-10 01:47
I've tried again today and had 2 drops during a long flight so all seems  ...
I'm sorry you are still experiencing this, the mini2 should work just fine.
Maybe talks to support and have it sent in to be looked at.
http://www.dji.com/support
2016-6-9
DJI-Ken
rliamharpurb Posted at 2016-6-10 03:03
Dji-Ken you mentioned to Tmygun he must have his settings just right to stop the altitude drop, wher ...
I was just guessing that, I have no idea of their settings. I do have my gains and sensitivity fairly low as I like a docile mushy flying feeling and not so rigid. If you have high settings and it's really rigid possibly lowering settings may help.
You would just need to spend a few batteries testing out different settings.
2016-6-9
rliamharpurb
I'll give that ago regarding settings then Ken,
Regarding the blurry photo feed I see others still expiriencing this online, is there likely to be anymore firmware updates to correct this and the tilted horizon?
2016-6-9
rliamharpurb
Ken do you think I should refresh the firmware install and the recalibrate everything before contacting support? Don't really want to be without the drone lol
Could this make an improvement?
2016-6-9
Mad_Angler1
Flight distance : 2741657 ft
Folks
Photo view is not the same as video and has never been as clear, image may look pixilated or blury compared to video live feed , the craft uses the sensor differently in picture view compared to video, this has always been the case with the P4 and P3.
This is nothing new
2016-6-9
Tmygun
rliamharpurb Posted at 2016-6-9 15:03
No settings change.
Just updated to the 1.1.411 firmware and the issue I had with the P4 dropping when you stopped from high speed went away.
Did not get a chance to install the 1.1.410 firmware but went straight to the 1.1.411.
2016-6-9
Tmygun
rliamharpurb Posted at 2016-6-9 15:53
Regarding the blurry photo feed I see others still  ...
The blurry photo feed is fixed in the 1.1.411 firmware release.
2016-6-9
Tmygun
rliamharpurb Posted at 2016-6-9 15:55
Ken do you think I should refresh the firmware install and the recalibrate everything before contact ...
I posted about my 1.1.411 update experience on the Phantom 4 forum this morning, but I can tell you that I recalibrated EVERYTHING after the update.
The main reson was that most of my P4 settings like RTH altitude, Max Flight Altitude, Obstacle setting had all reverted back to default after the upgrade.  I figure the IMU had also been flashed and needed a recal. Hope this helps.
2016-6-9
rliamharpurb
Still got a blurry photo feed guys
Everything is set correctly and up to date,
I will recalibrate the gimbal tomorrow to try and fix the horizon tilt
As for the blurry photo feed changing modes doesn't work and it is significantly less sharp of an image compared to when in record mode
Just wanna get this sorted
2016-6-9
Mad_Angler1
rliamharpurb Posted at 2016-6-9 22:25
This is normal see my post above
It's always been the case
2016-6-9
Tmygun
rliamharpurb Posted at 2016-6-9 17:25
What is the device you are using?
2016-6-9
Tmygun
I mean iPad Air, Mini, Android, etc.  ??
2016-6-9
Dida Sampaio
Flight distance : 31581 ft
Brazil
Hello , I need help.
since I bought my 4 Phantom
the monitor display signal is cut .
the display on the monitor screen is cut .
viewing return picture is blurred and cutting .
what should I do?
2016-6-9
DJI-Paladin
Flight distance : 2408 ft
Dida Sampaio Posted at 2016-6-10 11:38
Could you post a screenshot of this issue? What kind of mobile device do you use?
2016-6-9
Dida Sampaio
Brazil
Viewing the monitor is failing ... disappears and reappears out record the preview image
2016-6-9
Dida Sampaio
Brazil
DJI-Paladin Posted at 2016-6-10 11:44
TABLET GALAXY   ANDROID     VERSAO    5.02
2016-6-9
DJI-Paladin
Dida Sampaio Posted at 2016-6-10 12:11
2016-6-9
Dida Sampaio
Brazil
TABLET Versão ANDROID 5.0.2
2016-6-9
Dida Sampaio
Brazil
Hello , this device I'm using is compatible .
also already used the ipad mini 2 .
with the two device is failing the visuallização signal
2016-6-9
DJI-Paladin
Dida Sampaio Posted at 2016-6-10 12:30
with the two devi ...
Do you have a screenshot of this?Do you try to relink the Rc and drone?
2016-6-9
rliamharpurb
I'm using an iPad mini 2
Are you guys getting a blurrier feed in photo then video as mentioned above as being normal or are the feeds the same
Thanks again
Liam
2016-6-10
123Next >
