Chicago DP
Hey all you guys screaming about your Z Axis being late. I used mine for the first time today, thankfully not on a real gig! I was doing a location scout at car dealerships and figured I would bring the Osmo along to film tests. I thought my moves were OK, but now that I imported them I see a pronounced up and down bob. Don't mean to brag but I have practiced so much using the heel-to-toe Ninja Walk I was like a Stedicam. I figured with the Z Axis I wouldn't draw stares walking funny. However, the bob is WORSE with the Z Axis.
I had seen the tutorials including Osmotips and to keep the spring a little below horizontal, but here's the problem: You can't really tweak it on a real job when you're moving fast to keep a schedule because you'd have to keep ejecting the card to view it on a laptop, hard to see bobs on a phone, which is another drawback of not having it Bluetooth to a larger monitor. It may look OK on your phone but when you're watching on a 27" display, there's up and down bobbing.
In sum, it worked well when I ran straight forward but for regular Osmo use I guess I will have to remove it. ugh! In sum, I am better without it unless I plan to run straight forward.
http://www.vimeo.com/170098308
password: osmo
