joelgerlach
Hi all.
Just got the X5 adapter plate for the Osmo. But I'm stuck. The X3 works fine on the Osmo, everything works. The X3 even works when mounted to the X5 adapter plate. But when I attach the X5 onto the Osmo and turn it on... nothing. The Osmo won't display a wifi signal, the gimbal/camera doesn't move, all I get is the right green LED flashing for a few seconds and then turning solid, left LED remains green. Other than that, it doesn't work, at all. I know the X5 is fine because it powers up no problem on the Inspire. But for some reason the Osmo doesn't turn it on.
Is the problem have to do with the firmware? I don't know how to update the Osmo to run in the latest Pro firmware. I've put the Pro firmware on the SD card root directory and tried to update the Osmo handle both using the X3 and the X5. Even put the Osmo firmware on the SD card and tried to see if the Inspire would install it to the camera. But it ignores the firmware update in the X3 and obviously the X5 doesn't power on so it doesn't even get to the firmware update process.
What's going on?! How do I get the bloody thing to work? Been fussing at this for a while now and I've run out of ideas...
When the X3 is attached, inside of DJI Go it says the firmware is 1.6.2.10. So how do I get it to the Osmo Pro 1.1.00.10?
