GabeZ
Flight distance : 768448 ft
Hi Bhumme,
You need to downgrade your controller firmware. You always update the drone firmware first before updating the controller firmware. To do this, only power on your controller with you phone attached. Open the App, press and hold the little graduation cap in the top right corner for about 10 seconds and release. You will get a black screen with an older firmware version to download. Download and install that. After you are done, check for drone operation. Do not re-update the controller firmware. Then, update your drone firmware. After that, then you can update your controller firmware. |
