CrimsonPhantom
Flight distance : 179974 ft
DJI-Paladin,
The battery was brand new and the anomaly occurred after the first charge to capacity and then used for flight. Once I noticed it wasn't moving off 100%, I immediately landed and brought the battery in and continued to allow it to discharge by leaving the Phantom turned on and sitting idle. After discharge and power cycling the battery, it started to operate properly.
I've performed several charge/flight cycles and the battery is working without any issues. As huntcool001 suggested, it may have been just a blip.
I'll continue to watch it... but I think it's good. I thought this would also be worth mentioning to bring awareness to everyone. It's just good advice to check and ensure the battery charge/voltage is reporting properly before you go out flying a long distance and then realize you have no idea what the battery voltage is or how much capacity you have left. |
