New Firmware for Phantom 3 Pro/Adv has been Released
DJI-Paladin
Flight distance : 2408 ft
Guillaume62 Posted at 2016-8-17 18:39
yes, I did the update but I had no connection between the remote and the aircraft, so I turned off ...
If it has no reaction while charging, please contact support.eu@dji.com and send it in.
2016-8-17
Guillaume62
DJI-Paladin Posted at 2016-8-17 12:57
If it has no reaction while charging, please contact  and send it in.
Thank you !
2016-8-17
ppkessler
dbostock Posted at 2016-8-14 13:17
You can get it from here> http://www.phantompilots.com/threads/phantom-3-professional-firmware-v1-6- ...
Thanks but I was looking for the RC firmware, not the drone firmware. Sorry I was not clear   :-)
I found a way to get it.
Thanks again
2016-8-17
ppkessler
DJI, about power limitation, you are responsible of setting it as default but you have to offer the user, at his own risk and responsibility, to overide the default value to get back what he paid for!!!
Thanks
2016-8-17
melvonnar
DJI-Paladin Posted at 2016-8-16 21:35
If it is convenient, could you please post the hidden update log here?
I have contacted DJI support and will return the drone for repair--- thanks for your reply
2016-8-17
Homestead72
For all those who have done a successful firmware update  but sill having issues with  video feed lagging, cutting out etc etc.
I am on latest firmware for aircraft and rc.  Have latest DJI Go iOS app on an ipad mini 4.
I had the problem and after going to online support (chat) and posting on here in a separate thread, someone suggested disconnecting and then re-connecting the two cables that connect the gimbal to the aircraft.  After a bit of swearing and luck (it is fiddly) I got them back in and the problem appears to be fixed (on the bench at least).  I will do a flight test later and report back.
So if your latest firmware update went OK and you are having video feed issues , try re-seating the two cables into the gimbal.  (Credit to fellow Brit, DrawsWithLight who responded to my other thread this morning - Thanks!)
2016-8-18
dbostock
Hey Homestead72 thanks for the info. Not to dismiss what you just said, but how can this be the cause after the issue has occurred after a software update?
2016-8-18
Homestead72
dbostock Posted at 2016-8-18 11:06
Hey Homestead72 thanks for the info. Not to dismiss what you just said, but how can this be the caus ...
Hi dbostock,
I know it doesn't really make sense and there is no real logic but it did work for me and has for a number of others as well (from other threads).
I have still got a real flight test to do yet though before I am 100%.  I'll report back hopefully later today.
Stu
2016-8-18
TechReviews
Flight distance : 99852 ft
Homestead72 Posted at 2016-8-18 14:04
Hi dbostock,
I know it doesn't really make sense and there is no real logic but it did work for m ...
hi stu
I have replied to your post with regards to the latest fw update - 1.9.60.
Kind Regards
2016-8-18
Homestead72
Homestead72 Posted at 2016-8-18 10:40
For all those who have done a successful firmware update  but sill having issues with  video feed la ...
Just took it out for a short 10 min test flight after re-seating the gimbal cables and  and the video feed was fine and in sync.
2016-8-18
augiemercado
South Africa
Hi, I tried to update. Now I got a message on the app " no image transmission" nothing seems to be wrong except for that. Then I tried to update the aircraft using the SD card, it keeps failing. What can i do?
2016-8-18
DJI-Paladin
augiemercado@ya Posted at 2016-8-19 13:27
Hi, I tried to update. Now I got a message on the app " no image transmission" nothing seems to be w ...
Could you please post the hidden upgrade log here? The method could be found in this thread.
2016-8-18
Mark97564
Flight distance : 2067749 ft
If your p3 is working fine people, why would you even update it? The last update I did on my p3 pro was to get the extended functions on it back in like August 2015. I only did that to get the point of interest, waypoints and stuff onto the copter...  Once I finally had full functionality I decided no more updates!  They are been 2 battery updates since, 1 which caused the p3 to shut for mid flight and then another firmware to fix that issue..  So if your p3p is working good and has all its functionality why update?  At least save all the bin files from each firmware version, then you can rollback the firmware one by one until getting to one that works.  The way I see it as of last year my p3 finally had full functionality after a couple months after purchasing it and she flew the best it ever has since the real botched firmware at the beginning...  So what is the point to even updating it anymore? To increase the number of places it won't fly or need authorization? NO THANKS!  So anyone with a p3 or p4 or even a p9 when it gets released, if it has full functionality and flies great just leave it, the firmware upgrade clearly isn't for you, ya know....  Lol...
And for DJI, we all know you mess up firmware and my own p3 dropped 50 plus meters due to that bad firmware that messed a huge number of people's phantom 3's up.. It was more than proven! That is what caused DJI to make it possible to roll back firmware on the p3 ..  The copters had issues realizing their altitude and that's it the firmware release notes, not to mention all the compass errors I would get, a video downlink that was crap, 200 meter range!  2 months later Good firmware was finally released and all those issues were solved! I've never seen a compass warning again! The vps hasn't caused anymore flight issues, and I haven't seen my p3 idle its motors while 100 meters high and drop 50 meters before deciding to hold altitude again...  Not to mention my home arrow finally worked properly again after pointing the wrong direction coming back to its take off point.  At least I was able to to follow the green line on the map to get back to ho,e location if need be.
So please, don't try feeding us crap that a firmware update  can't cause video link issues, compass issues or cause a fly away...  Because we all learned a few times now DJI isn't perfect and their firmware updates can and will cause crashes!  Unlike my flame wheel's with naza, the phantom 3 doesn't even have a MANUAL mode available for being able to recover from compass and gps issues and glitches or any other auto pilot issues...  So you build something and sell it as full atonomous with all these abilities but then it fails for what ever reason and flies off and we have no manual mode to recover from it? The. I believe the warranty should be replacing these things and DJI needs to stop saying it isn't the firmware, especially when their are multiple people who upgraded the same machine to the same firmware version and have then developed the same exact issues...  Come on here DJI...
On a side note though, besides that botched and well known and documented firmware release for the P3 in May 2015 I've been extremely happy with my p3, its range, and how stable it flies.. Even in 25mph winds its rock steady..  I love my p3. And I've been lucky so far and haven't had it or my naza v2  copters fly off or do anything stupid that would make me feel afraid to fly em...  All my DJI products have my confidence now....   Well except for all my e300 motors failing on me.  Which caused my X4 3dr copter to fall out of the sky 60 meters up and start on fire cuz of the lipo battery hitting the ground and getting punctured..  But in all honesty they are about 4 yr old motors with plenty of flight hrs on em..  Less than 100 hrs though which the motors are said to last..  But my e310 amd e305 propulsion systems. Are still running great though, lol...
2016-8-20
guenter.gran14
Flight distance : 823510 ft
Mark97564 Posted at 2016-8-20 22:14
If your p3 is working fine people, why would you even update it? The last update I did on my p3 pro  ...
In Germany is discussed, that has reduced the DJI transmit power to 10mW by the latest update. DJI has not informed its clients in advance. Is there already a response from DJI?
2016-8-20
dbostock
Why was this done to just the P3, or is it same for P4 also?
2016-8-20
AchimS.
Is it bad that I have made the update v1.9.60 directly from the v1.6.0040?
I'm asking, because sometimes i got  the message "no image transmission" in the app
Here is the hidden upgrade log:
2016-8-21
DJI-Paladin
guenter.gran14@ Posted at 2016-8-20 23:45
In Germany is discussed, that has reduced the DJI transmit power to 10mW by the latest update. DJI ...
The firmware has nothing to do with the RC transmit power. We have no reason to reduce it .
2016-8-21
DJI-Paladin
AchimS. Posted at 2016-8-22 04:35
I'm asking, because somet ...
This log is normal. But please make sure your RC has been updated to the latest 1.6.0 firmware. Then relink the drone and RC.
2016-8-21
rosteer
Mexico
Hi my phantom 3 advanced is dead fot the new update i put new firmware  and yes update but my rc not have not work and sendme need  upgrade the controller but is upgrade  dji need fix the firmware have lot users not have work the aircraft
2016-8-22
kevy
Well, I have the Phantom 3 professional (4k) that had a litebridge range of well over 1km.
Now it's 300-400 metres before I lose the litebridge live view signal. It lags, flashes green and then black. You can tell the drone still responds to controls via line-of-sight so it's not 'out of range'. Something was nerfed in the new firmware. It's hard to believe they didn't reduce the transmission signal strength on the remote or drone. Now DJI claim that the range is only 500 metres and that's NORMAL!!! In clear contradiction to the specs on the Phantom 3 professional product page that state a range of up to 3.5km.
Comments?
Thank you for your email.
As to your description, it get this problem while getting to a distance of 300-400 meters, which means it is a normal situation.
Kindly be noted the detail as following:
Max Transmission Distance
FCC: 1200m
CE: 500m (unobstructed, free of interference, 120m above takeoff point)
In real flying environment, there should be more or less interference around, which will affect the range of image transmission. Hope you can understand.
Best Regards,
Justin
DJI Technical Support
2016-8-22
davido
Flight distance : 8688 ft
My Phantom 3 Advanced when I got it came with firmware 1.6 in both the Phantom and the controller. I finally got the firmware upgraded on the Phantom itself by copying the firmware to the SD card.  However nothing I've tried will the controller firmware to upgrade and the "Overall status" screen never shows that the controller needs an upgrade.  Shouldn't both the controller and the Phantom unit both upgrade to 1.9?  So far nothing I've tried has gotten the controller to recognize the BIN file on any thumbdrive, etc.
Thanks!
2016-8-22
dbostock
Will it work if I downgrade my P3P from firmware v1.8 to v1.3.20 on download page? Otherwise Im sending mine back. 500m is ridiculous
2016-8-22
DJI-Paladin
dbostock Posted at 2016-8-23 07:13
Will it work if I downgrade my P3P from firmware v1.8 to v1.3.20 on download page? Otherwise Im send ...
No,1.8 firmware cannot be downgraded to 1.3.2 version.
2016-8-22
DJI-Paladin
davido Posted at 2016-8-23 06:14
My Phantom 3 Advanced when I got it came with firmware 1.6 in both the Phantom and the controller. I ...
The latest RC firmware is 1.6.0 and if there is an update for the RC, you'll get a notification from app and upgrade via the app.
2016-8-22
DJI-Paladin
rosteer Posted at 2016-8-22 18:45
Hi my phantom 3 advanced is dead fot the new update i put new firmware  and yes update but my rc not ...
Please replug thees cables and use the latest firmware to upgrade again. For the RC,if it is running 1.3.2 or later firmware,please upgrade it via app: 6pin和8pin线.JPG
2016-8-22
davido
DJI-Paladin Posted at 2016-8-23 09:42
The latest RC firmware is 1.6.0 and if there is an update for the RC, you'll get a notification fr ...
Ah ha!  Got it now.  Thank you!
2016-8-22
DJI-Paladin
davido Posted at 2016-8-23 12:18
You are welcome
2016-8-22
knupla2
Flight distance : 922 ft
SUGGESTION TO DJI-Paladin:
How about NOT leaving a post at the top - that is more than 2 months old - that there is a "new" update.  Perhaps consider adding the DATE OF THE UPDATE in the thread title.  We shouldn't have to filter through 14 pages of old data to find the latest information.
Thanks.
2016-8-25
mana.ram.1974
Flight distance : 1531355 ft
FAS1 Posted at 2016-6-13 05:49
If it works for you, then fly it. Updates are only 'suggestions'. I am still on 1.4.6 and have no de ...
have you upgraded the app?
2016-8-25
dbostock
Hi All,
So this morning I decided to record the issue.. also dont tell me to upgrade the firmware from 1.8 to 1.9 because the problem is worse if I do this. This is only a 1minute out take, but it was happening most of the flight. Happy for anyone let me know the fix before I send it in. (video is only 8mb)
Check this video ->> Phantom 3P signal issue
2016-8-26
ksensenig
Flight distance : 110577 ft
Greece
Hello,
My P3P was working fine until it stopped getting a signal and displayed "No Image Transmission". I had been following everyone's advice on here not to upgrade my firmware unless I was having problems, so now that I had a problem, I decided to try to upgrade. I upgraded the Remote Controller firmware via the most up-to-date iOS DJI Go app. It seemed successful, and told me to restart the Remote Controller, which I did. When I restarted, it took me back to the same place and told me I had to upgrade to Firmware 1.6.0 which is the upgrade I had just completed. I repeated the process many times, and it still gives the same result. Has anyone seen this, and how do I fix it? I even tried doing the P3X_FW_V01.04.0010.bin update with an SD card, but of course I already had that version installed on the Phantom itself, so that didn't do anything.
Thanks for any help,
Kurtis
2016-8-27
wntmldrs
Flight distance : 793281 ft
Please, please. Close this thread. And open a new one as soon as the new firmware is in the open.
2016-8-27
dbostock
Hey ksensenig@gm check out my video above. Is your problem the same?
2016-8-27
scotthayne
Since the latest update to both RC and P3P I have had two issues.  One is the image transmission that others have mentioned here, though much worse.  iPad screen glitches, goes partly green, freezes ets - and at ranges of even a dozen feet while preparing for takeoff.  That is assuming I could take off - because the other issue that has instantly appeared is that I cannot get the compass to calibrate so it will not let me take off.  I have tried dozens of times in far ranging locales, all in a park way outside of the city and any possible interference.  I managed to get it to pop to green for a quick second and takeoff during which I was able to confirm that the video recorder to the SD was flawless, even though I could barely watch via the iPad.
One really odd thing that I noticed was while trying to take off, the banner was red telling me to calllibrate the compass.  If I picked the aircraft up and tilted it jus a few degrees the banner would turn to green (safe to fly).  Tilting it back to horizontal brought the red banner back.  Extremely odd, but repeatable.
I have downgraded to 1.08 and 1.5.8 for the RC and the problems persist.  There were zero issues before this upgrade, and seemingly now even when rolling back they persist.  I wish I could go back to the 1.06 firmware on the P3...
2016-8-27
fzLdfvgycbLI
Hello all, newb here but not new to the p3p and p4. I too have the "No Video Signal" problem since they pushed this update out. and I've been trolling this board trying to find a solution with no luck.
Has anyone found a way to downgrade the firmware on the drone itself?
I work in construction and I convinced my boss that this would be a great tool for roofing and building exterior projects, and now that I really need it, this happens. He was planning on buying several more for our entire Redevelopment team throughout the country. But if I can't get this fixed and ASAP I guess we won't be making that purchase.
THIS IS REALLY FRUSTRATING!!!!
2016-8-27
rasco
When I open dji go and go to phantom 3 advanced it tells how to hook everything up but it will not let me go to the camera , I've repeated the app then redownloaded it still the same no camera where did I go wrong
2016-8-27
ramseyc
I have tried everything to get my range back.  Is there a fix for the range reduction in one of the firmware updates?  I can't fly anywhere near the distance I used to obtain.  I used to be able to fly about 2400ft from my house @ 250ft to 400ft altitude.  Then a firmware upgrade came out and I lost more than half my range.  I don't want to hear that it is due to local interference.  I am not buying that one, especially since my flight logs can prove you wrong.  I know you reduced the number of channels we can now use.  Is this the root cause of the distance issues?  I spent a lot of money on my p3a for my range to be reduced to less than a quarter mile.  I don't expect to get the advertised range of 3 miles.  I do expect to be able to fly my p3a farther than 1/2 mi to at least 1.5 miles.  Now that should be acceptable when you do advertise 3 mile range.
Any help?
2016-8-27
ramseyc
Oh did I forget and mention that video lag doubled also?  Sometimes while even setting on the ground 25ft away.
2016-8-27
dbostock
Hey ramseyc, did u see my video above? .. same issue as urs? Apparently issue is hardware and not caused by firmware update if u have a read through previous discussions
2016-8-27
kevy
What do you mean it's due to hardware? Do you recommend unplugging and replugging the cables as suggested above?
2016-8-28
