Phantomski
Flight distance : 14869882 ft
OK, in hope of maybe helping someone...
My rc is on 1.6 version, I have the latest dji app on my Android. nothing needed there.
My drone was on 1.8.80 firmware.
I downloaded the newest firmware from here:
https://dl.djicdn.com/downloads/phantom_3/P3S_FW_V01.09.0060.zip
Then on my PC I unzipped the file, and got the .bin file from it:
P3S_FW_V01.09.0060.bin
I took my microSD card from the drone, then formated it (I am in windows) as Fat32 (I have a 32GB card).
I put the P3S_FW_V01.09.0060.bin file in the root of that sd card.
Then, with RC off, i just put the card into the slot on the camera in my P3Adv and started up the drone, it does it's initialization, few extra things, then starts beeping and the lights on the camera alternate red/green. This takes 10-15 minutes, then the light on the camera is green (cannot remember if steady or blinking).
At this point i turn of my drone, replace the battery and repeat the process - now it takes only about 5 min. I repeat it for the 2 extra batteries I have.
When done, i get the card back onto my PC and check the .txt file, which confirms that I actually updated 3 times, as i have total of 3 batteries. I reformatted the card again, just to get a clean start.
I have heard of people having to remove the .TXT file after each uptdate, i have also heard of people having to reformat the SD card and put the .bin file on again, for each battery update.
If your RC is on a version older than 1.6, it needs an upgrade, and that should happen via the GO app, at least on android. Not sure on iPad....
Once the RC is at 1.6 and the aircraft is at 1.8.80 or the current 1.9.60, things should work, but if you do not get a green light on your RC you may have to link it again, and there's bunch of tutorials on that, just google it.
If you have issues with the tablet connecting, make sure you have the latest dji app. If the RC LED is green and u can control the gimbal with the dial, the issue got to be on the tablet (remove and reinstall dji app - AFTER SYNCING FLIGHT RECORDS...?) If LED is RED u need to relink.
This is what worked for me... hope it helps someone....
When u r all done, confirm in DJI app, menu, (...) about, and confirm your versions of djiApp, RC software version, and drone firmware version.
