mtrascal2000
I tried this down load, same thing happened green light on and buzzing. Tried direct connection download with sim card in the P3A and next deleted everything of the root directory downloaded directly to the sim via usb installed the sim back in P3A same thing, had solid green led's on rear legs. Did some check runs with props off all appeared to work OK, took the bird out for some low level flights (winds gusting to 37kn) appears to be working fine.When I checked the log that didn't show that I had done an update. This was on June 14.
cheers
