treeboy
Flight distance : 604747 ft
johngreydanus Posted at 2016-9-24 13:08
I did something similar with mine, the new Samsung Gear VR 2016, but instead of having the connector flipped up, I used the second connector and ground out the inside of it.
This way the phone stays centered where it's supposed to be!
Instead of grinding the connector (USB-C) down you can just remove it for later use, from the adapter by removing the four, albeit tiny, screws. The connector then comes out and you can replace the part with the four screws. |
