Hello everyone. I am really bad with electronics and i was wondering if there was any cheap under $75.00usd droppers for the phantom 3 Standard? This device should allow me to drop a small parachute or candy from it. I have very little experence with electronics so could i find one that would be easy to install?
You do not want to use any kind of attachment like that.
It is blocking the sonar in the VPS from getting a good return from the ground and the waves would mroe than likely bounce off the dropping mechanism and cause erratic altitude adjustments.
