wichhojr
Flight distance : 34386 ft
Hello Adela,
I do not have an X5R camera. I am working with a standard Osmo, right out of the box, with the Zenmuse X3 installed.
I followed your instructions: I formatted a new SD card, loaded it with the firmware 1.6.2.10, and inserted it into the camera. I booted the Osmo, did the "Trigger+Record+Power Switch" to reset the firmware. The Osmo behaved as it should - power light blinked red, status light blinked green, but it never reached an end point. It just kept going. After about 8 minutes the camera was extremely hot, so I turned it off. I removed the SD card, copied the OSMO_FW_RESULT.txt file to my hard drive, and the re-formatted the SD card. I put it back into the Osmo and re-booted.
After all this, there was no change in the Osmo's behavior: The handle status light still flashes green, indicating that the gimbal is locked. The status line on the DJI-GO app says "gimbal is locked, unlock by hand."
The camera will take stills and videos, but the gimbal stays limp.
What next?
Thanks,
wichhojr
PS, the text of the OSMO_FW_RESULT_AB.txt file is below:
========== 2014.01.01 00:00:08 remo-con disconnect======
Packet: OSMO_FW_V01.00.01.19.bin
Upgrading ...
Result: Success.
Packet: OSMO_FW_V01.06.02.10.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:07 remo-con disconnect======
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the device.
========== 2014.01.01 00:00:09 remo-con disconnect======
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2016.06.27 01:16:04 =====================
Result: Abort.
========== 2016.06.27 01:17:11 =====================
Result: Abort.
========== 2016.06.27 01:17:34 =====================
Result: Abort.
========== 2016.06.27 01:18:17 =====================
Result: Abort.
========== 2016.06.27 01:19:32 =====================
Result: Abort.
========== 2016.06.27 01:20:23 =====================
Result: Abort.
========== 2016.06.27 01:20:50 =====================
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the device. |
