jpe2459
Lightbridge Air and Ground units on my S900 have been working flawlessly since day one, no problems. Have not flown my rig for about a month. Yesterday decided to take my rig out and go play, but things were not working right at the start. Decided to look at things and verify software. A2 seems to be fine along with everything else. But when I connect the Lightbridge Air unit to the computer using the Lightbridge Assistant 1.3 it does not see the air unit or ground unit when trying to verify software. Uninstalled LB Assistant 1.3 and then reinstalled to see if that made a difference. No change. Lightbridge Assistant 1.3 does not see the Air or Ground units. Also tried it on my other computer, again LB Assistant will not talk to the Air and Ground unit or vise versa, air and ground will not talk to LB Assistant, however you want to call it. Any ideas? |
