Phantom 4 Gimbal not pointing straight
3520 10 2016-6-29
velascoborja
Flight distance : 1427326 ft
Hello!
I own a Phantom 4 and I've recently realised that the gimbal is not pointing straight, it points a little bit to the right, like 2 or 3 degrees (as you see the phantom from the back). I've never crahsed it and I've tried to do a cold IMU calibration, an auto Gimbal calibration and a Compass calibration without success.
I would like to know if the Phantom 4 camera isn't supposed to point perfectly right, if there is some way I can get this fixed, or should I return it and get a new one (I bought it in an Apple Store and I'm still able to do it). I've been searching through the forum and I only came across with some people experiencing this issue but with P3 models.
Thanks in advance.
2016-6-29
DJI-Jamie
Flight distance : 112405 ft
To clarify, what gimbal mode is your unit in? Have you ever moved the unit while it is initializing? Could you provide either a small video or picture of the extent of the tilt?
2016-6-29
velascoborja
DJI-Jamie Posted at 2016-6-30 06:56
To clarify, what gimbal mode is your unit in? Have you ever moved the unit while it is initializing? ...
Hello!! This happens both in FPV and in Follow mode. I've never touched it but I once forgot to remove the gimbal clamp when turning on. Could that've caused this?
I attach some pictures for you to take a look.
2016-6-29
DJI-Jamie
velascoborja Posted at 2016-6-30 15:10
Hello!! This happens both in FPV and in Follow mode. I've never touched it but I once forgot to rem ...
There may be some causality if you noticed this after that incident. Do you notice any grinding noises or anything audibly out of the ordinary?
2016-6-30
BrianJ
I had this same problem with my new Phantom 4 and had it replaced Click Here For My Post
2016-6-30
velascoborja
BrianJ Posted at 2016-7-1 03:20
Thank you very much for your reply BrianJ. I've reading about the issue and I'm going tomorrow to the Apple Store to get a replacement. Hope the new one works as well as this one except from the gimbal's yaw.
2016-6-30
yrlehr
Flight distance : 1087362 ft
Singapore
I am have a the issue my gimbal is turned just slightly to the left.. were you able to get a replacement from dji ?
2016-9-25
fans2053cede
Flight distance : 54803 ft
Malaysia
I also got this problem...  I've tried to do a cold IMU calibration, an auto Gimbal calibration and a Compass calibration without success.
2017-1-7
TexasTurbo
Flight distance : 1172484 ft
fans2053cede Posted at 2017-1-7 07:57
Return it there is a problem. My first p4 had this issue.
2017-1-7
BigMikeL
What did you need to complete the return?  I cannot find a way to register my purchase with DJI and worry that if something goes wrong they will not work with me since the product is not as yet registered.
2017-1-8
dorbot
Flight distance : 844770 ft
2018-1-14
