AG0N-Gary
Flight distance : 700846 ft
In your picture above, you are holding it upside down. Flip it 180 degrees counterclockwise, so that the "L tray" at the top of your photo is facing away from you and is at the bottom. I struggled with how to properly install mine for awhile. Then, I took some of the guess work out of it and marked the spot where you put your thumb when removing it. That way, I grab it the same way each time to install it. I also standardized my method of installation. Lay it at an angle on the right side, leaning on the right arms, props parallel to the table you lay it on, and the lower right leg corners. Then insert the gimbal lock from the opposite (left) side, sliding the flat tray (upper part in your hand above) under the camera and align the "channel" at the top of the lock so it slides between the two aluminum tabs on the bottom of the gimbal. Gently but firmly push it onto the gimbal until it won't go further. If you do it this way, it will not come off until you want it to. Note: when firmly seated, it will be slid up to the gimbal azimuth arm shaft with the plastic "channel" fully seated both horizontally and vertically.
Edit: While I was typing the above response, Paladin posted pictures that I couldn't provide. They are excellent and show the channel and alignment with the tabs. The installation it not perfect in his final two photos though. Notice in the side shot that the camera is not flush on the back of the lock tray, and in the front view it is not locked up flush with the gimbal. If you make certain that the camera is fully seated in the tray, and the channel is fully inserted in the slot, it should be flush all around and not allow any movement, other than the gimbal on the rubber mounts. It has to be "pried" off with the fingers when it is properly mounted, and will not remove itself. It seems many of them arrive with the gimbal lock laying in the bottom of the box, presumably because they weren't fully seated before shipping. Mine has never come off until I removed it myself, even when transporting on rough roads.
