Donnie
Flight distance : 3636782 ft
No the Home point is still the same , it will not change with the POI setting . The POI flight will continue to circle until you cancel it and then you fly home manually , I would not let a building come between you and the Aircraft at any time . You should be flying above the point of interest anyway.
Yes, you can switch anytime between P- A- F modes no problem . If you are in F mode mode do not engage to P or A mode during a mission or it will be cancelled, but that is alll that will happen.
If the aircraft begins mis- behaving in the air from a bad GPS signal the best procedure is to switch to A mode and gain back control and then try" P "( GPS) mode again.
Hope this helps
donnie
donnie |
