Geebax
Moving it left or right will not work, the aircraft has to be moved or yawed to move the camera. The camera should do a little dance when it starts and finish up with the camera pointing ahead.
If this has happened after you did a firmware upgrade, then it is most like a case of the gimbal firmware upgrade was not successful. An upgrade consists of a number of sections, there is one for the gimbal, so I would do the aircraft upgrade again and see if it cures the problem. It may be necessary to downgrade the aircraft and then upgrade it again,.
