DJI-Jamie
Flight distance : 112405 ft
Support may be the best course of action. As a last ditch effort, you can try the following:
-Try to downgrade the firmware and reapply the most current.
-Reset the RC of any unwanted presets by using the following button combination:
* Turn on the controller, and the aircraft should be off.
* Press C1, C2, and shutter on the controller then turn the controller off.
* Turn on both the aircraft and the controller and link the remote.
Relink the RC manually with this button combination:
* Turn on both the aircraft and the controller.
* Press C1, C2, and the record button on the controller, then the controller will beep like D-DD.
*Let go all fingers, press the wheel on the right side of the controller and then the first light of the controller will become blue and it will constantly beep DDDD.
* Use a pen to click the linking button on the aircraft and hold for 3-5 seconds, and then take the pen off the aircraft and wait, it will be linked soon.
The button combinations would ensure that the Lightbridge module is refreshed on both the aircraft side and the RC side. If that doesn't work, a RMA would be the next move. |
