Gimbal X5 No green LED DJI Support says no issues found.
1595 10 2016-7-20
sundayvaldez
Please help, my Gimbal LED does not go green, I spoke to support and they couldnt figure it out so they had me send the unit in, I received the unit and the problem is still there.
the invoice said no issues found, this all happened after the 1.9 firmware upgrade. and all they did was upgrade it to 1.9.1.3,
Does anyone no what I am talking about when the unit is starting up and the gimbal goes through its systems check the LED by the LENS stays green when ready. mine does not and it did until the FW update.
I am going to try posting a video. Please excuse the RMA stickers i sent it in with. and I tried it with a fully charged battery outside.
Click here to see video let me know what you think, Thank you. Sorry about the video interference noise.
2016-7-20
Aeromirage
Flight distance : 1778045 ft
I had that problem as well as the loss of the focus assist and odd iso levels. Downgrading fw fixed all. See: http://forum.dji.com/thread-52361-1-1.html
2016-7-20
DJI-Paladin
Flight distance : 2408 ft
Hello sundayvaldez, don't worry about this if this led works well in updating and recording.It is designed to perform like that in the latest version firmware.We will update the manual asap.
2016-7-21
blades
Hi sundayvaldez
Did you get a solution to this? Same thing has happened to me.
2016-8-9
DJI-Jamie
Flight distance : 112405 ft
blades Posted at 2016-8-10 03:16
Hi sundayvaldez
Please read Paladin's response. This is a new design change in recent firmware updates. Are you experiencing any performance issues?
2016-8-9
blades
DJI-Jamie Posted at 2016-8-9 23:04
Please read Paladin's response. This is a new design change in recent firmware updates. Are you exp ...
Hi Jamie
I still have to calibrate the camera. I will check everything once this has been done and update you.
Can you guide me to where I can find a tutorial on gimbal calibration please?
Thank you for your assistance
Dave @bladeworx
2016-8-9
DJI-Jamie
blades Posted at 2016-8-10 13:34
Hi Jamie
I still have to calibrate the camera. I will check everything once this has been done and ...
No problem.
To calibrate the gimbal, you would hit the Auto Calibrate button on the Gimbal Settings section in the top right drop down menu in the app. For calibrating the lens, you would go to the camera settings, which is indicated by the wrench icon, and hit calibrate again. It will provide you with the instructions on how to calibrate the lens properly.
2016-8-10
blades
DJI-Jamie Posted at 2016-8-10 19:18
No problem.
To calibrate the gimbal, you would hit the Auto Calibrate button on the Gimba ...
Thank you again Jamie
2016-8-10
DJI-Jamie
blades Posted at 2016-8-11 02:40
You're welcome.
2016-8-10
ZEN.alfa
Indonesia
DJI-Paladin Posted at 2016-7-21 16:11
Hello sundayvaldez, don't worry about this if this led works well in updating and recording.It is de ...
i have same problem ... my i1Pro does not light green again since upgred to v1.9... ohh dji what are u doing??? please comeback green led indicator for us..
im feel to be more confidence with green led, so for me the led like show me its a gimbal in a normal condition..
2016-9-29
ZEN.alfa
Indonesia
DJI-Paladin Posted at 2016-7-21 17:11
why DJI change this?? i feel comfort if i see continual solid green led shown, ... because in my mind solid green led indicate the gimble in normal condition without see in dji go app, ... and i think many owner i1p will not like that dji do.
please dji, come back gimble green led continual for us...
2016-9-30
