Quadrocopter
Flight distance : 250125 ft
The Vue Pro, which is what we use, has bluetooth and PWM inputs to change various settings along with it's app and in flight.
My setup is a little unique, in that we are using a Ronin MX gimbal, and mounting the Vue Pro next to our other camera. Flir makes a HDMI converter for the Vue's, but we don't use it. Instead we input the analog video into the LB's Analog port, much like you'd do with a gopro or FPV camera. One could get a PWM video switcher, and toggle between a gopro and the Vue if they so desired.
We control our Ronin gimbal with a Futaba 14SG so that we can use the R7008SB reciever and use PWM outputs to control our main camera's zoom and shutter, as well as change through the different pallets on the Vue Pro; while also controlling the gimbal.
We don't have full 360 degree motion with our Ronin, and have locked it in at more like 270 so that our wires leading the the M600 don't get twisted when we aim the gimbal left or right.
You can have either the HDMI or Analog video on your app at a time, not both. To have both, you need to utilize the Picture in Picture feature by plugging in an external monitor to your M600 controller.
