So the thing is I was flying my drone in Hungary. There wasn't any magnetic stuff nearby, or big buildings. I was outside from the town and shooting an image film for a factory.
I flew 2 times, and now see it your selfs:
At the first pic it was everything okey but than it just lost the GPS signal and I don't know why? I don't saw it when I was flying with the Inspire 1 Pro, I just saw it when I got home and checked the Flight List.
Please guys can you help me out? I upgradid the newest FW today: Inspire 1 Pro Firmware v1.9.1.30 and this was the first time I see this - No GPS signal- in the Flight List.
DJI-Ken Posted at 2016-7-27 23:11
I think you are fine, it looks like you were at an extreme angle by your stick movements. when it ha ...
Thanks a lot for your comment.
Ken the thing is it happens when I don't do extreme angle movements by my stick. This is why I don't understand the situation. Maybe its an FW problem? Because I don't have this problem before.
Okey, I won't open it up, because I have 1 year warranty. The thing is I don't have this problem before, so I think the NEW fw will be the cause of the problem.
Thanks guys for all the replys. Really it helps me a lot!!!
If it claimed to be a successful update, you would need to downgrade to one previous firmware and then you could use the same .bin file to reapply firmware.
I believe another forum member may have created their own video on downgrading, unfortunately DJI does not have a tutorial on the subject.
Essentially, you would perform the same update process as you have with just the previous firmware. After that is done upgrading, then you would update again to the newest firmware. You would format the SD card prior to updating the craft to ensure there are no leftover .bin files.
