userd3297a459c
Hey,
Have a problem, question
On my rig i have installed,
1 Futaba 7008 for drone controle
1 Futaba 7008 for gimball ( some times used with other controler when working with camera pilot, some times with 1 controler in dual mode when working alone.)
I have also recently installed a DJi Lightbridge, to a Sony a6000 via HDMI.
All works perfectly fine, good image, good control.
Untill drone flies 100m away. ( or less)
1- i get a alarm from the light bridge module, that there is no radio transmitter reception ( although the drone keeps on being controled well even further - strange)
2 - reception of Lightbridge falls away quickly after 100 - 150m..
What i tried out:
Check all the antennas
Not being sure the were all Ok, i replaced them all with brand new ones.. from the brand, not some knock off..
Then checked the antenna placement of the Light bridge,
All good ( i think)
So what to do next?...
Any ideas.
I have 1 confession, it might be that the tablet isnt in aircraft mode, could that be a problem?
Or could it be the BTU of DJI is the bady?
Or should i re position the Futaba 7008?
Any ideas ?
Thanks ju
