I damaged my Transmitter USB board and needed a new one. Found one on Ebay that said it was for P3 Professional, Inspire and P4 but mine has 3 IC chips and this one has NONE. Here is a PIC of the two. Someone at RC-GROUPS said there were several versions of the transmitter board and the replacement board - sans ic chips - might work. Can anyone at DJI please take a look at this photo and tell me why mine has 3 chips and replacement doesn't and if it will work? I don't want to crash this thing.
Which is your RC model, GL300A or GL300B or GL300C? For GL300A version, you should select the PCB with 3 ICs. For GL300B or 300C model, you need the one on the right.
It's the GL300A. And the board was the 3 chip version. So the no chip version will not work in the transmitter at all, correct? Because I tried it and the Go App never connected.
